Guest projectfocus Posted August 23, 2005 Posted August 23, 2005 I am not sure how to get hold of the firmware anymore. The place I used to work burnt the chips there. I am not sure how you could get hold of the firmware now. I would say you would have to talk to a reaseller of LG stock to get it now.
Guest jpsc Posted August 23, 2005 Posted August 23, 2005 I am not sure how to get hold of the firmware anymore. The place I used to work burnt the chips there. I am not sure how you could get hold of the firmware now. I would say you would have to talk to a reaseller of LG stock to get it now. 65525[/snapback] I've just bought a secondhand GDK 162, if the firmware is more recent I'll swap the processor boards. I presume all settings are stored on the boards and I can just swap back to restore the prevoius setup.
Guest projectfocus Posted September 1, 2005 Posted September 1, 2005 that is true but if you go up a few firmware levels it will ruin the programming. Say from level 1 to level 5 will give major issues.
Guest jpsc Posted September 1, 2005 Posted September 1, 2005 that is true but if you go up a few firmware levels it will ruin the programming. Say from level 1 to level 5 will give major issues. 66695[/snapback] I'm talking about swapping the entire MPB complete with MPU, so both the firmware and programming move, allowing me to experiment with one board and instantly switch back to a known good setup when I need to. Any it turns out that the firmware in the s/h system is B.0Kf and has no WTIB/DECT support (B being earlier pre-release software than E I suppose, even though the date is later).
