C & K securitech
Guest julescollins
Hello Julie,
As the others have said I would get it serviced for peace of mind, the back up battery will definitely need replacing and the charging circuit etc checking. The engineer will go through the programming for you. Why not post your general location and I'm sure someone local to you will drop you a line.
Are you using the correct night set routine CODE , * , 0.
Have you tried manually omitting zone 2 , CODE , * , 2 .
As others have said , get it serviced , your panel is on borrowed time .
Regards.
You're best option would be to get a company out to look at it, it needs this particular problem sorting out, and a service.
You should also have it serviced annually, so ask about a maintenance contract, although an 8 year old 800L may be passed it.
59389[/snapback]
AN 8YR OLD SYSTEM PASSED IT :blink: IM STILL SERVICING 25 YR + SYSTEMS..
AN 8YR OLD SYSTEM PASSED IT blink.gif IM STILL SERVICING 25 YR + SYSTEMS..
And Older....flippin 26L's... :yes:
Tustall Ts500 / Munford & White anyone? :cry:
Chris Teague (Sales & Operations Manager) Sightguard Intruder Division
Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440
Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company
59537[/snapback]
i reset one once...cool or what B)
AWESOME.. :yes:
State of the art 40 years ago..
Guest RICHL
59535[/snapback]
An 8 year old UNSERVICED 800L.
I hope he's got a fire blanket.
AWESOME.. :yes:
59548[/snapback]
joking a side..have you ever seen a system better installed with its own lace wire and rawlbolted to the wall..the bell well thats just something else
What happened to the idea of 'interesting old installations/panels/bells' that was discussed ages ago along with the rouges gallery?
