Guest thomo Posted April 8, 2003 Posted April 8, 2003 has anyone on here know of where i can get spares for the fai " security guard 3, you will all fall about with lol but it seemed a good idea at the time,but you live and learn dont you .................... pir eats lithium pp9's do i need a new one ???also would like a servivce manua maybe this is not the right to ask for for but i fell hard done by allready !!!!!
Service Engineer Posted April 8, 2003 Posted April 8, 2003 Im totaly stumped, this is one panel ive never even heard off, but as a rule a good quality battery such as Duracell should easily last 12 months in a wireless detector where the cheaper batteries will only last upto a couple of months, ensure you are using the better ALKALINE batteries. Give a little more information on the panel, perhaps its another model i might know in disguise. ........................................................ Dave Partridge (Romec Service Engineer)
Service Engineer Posted April 9, 2003 Posted April 9, 2003 After doing a little research it seems that this panel is manufactured by NESS for FAI, designed to be mounted in a corner, keyswitch or keyfob operated only. There are manuals available from http://www.ness.com.au It is also called "The Post" and is a stand alone unit that sits in onecorner of the room. Hope this helps. ........................................................ Dave Partridge (Romec Service Engineer)
arfur mo Posted February 21, 2006 Posted February 21, 2006 has anyone on here know of where i can get spares for the fai " security guard 3, you will all fall about with lol but it seemed a good idea at the time,but you live and learn dont you .................... pir eats lithium pp9's do i need a new one ???also would like a servivce manua maybe this is not the right to ask for for but i fell hard done by allready !!!!! i do not know of this equipment, as it requires a fair 'punch' of current to transmit, radio detectors save battery power by 'sleepin' for 3 minutes after the last activation has occured, a bit like an auto-flood light in inverted operation. if the LED is showing on every movement, this will likely be the 'problem'. it's possible you have the detectors in 'walk test' mode, you should have a link or switch to move or adjust to place in 'normal' or 'set' mode, it may be simply marked as 'walk' or 'test'. hope it helps B) . If you think education is difficult, try being stupid!!!!
Guest Posted February 21, 2006 Posted February 21, 2006 That's got to be some sort of record, replying to a post that's nearly 3 years old.
kka Posted February 21, 2006 Posted February 21, 2006 has this happened again?, where a old post has come to the top of the pile, and some one has replied to it. ( sure it happened to me on feb 14th. the topic then was sl compact and it was in the diy section of the public forums) Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
