Omega 5 zone problem
Guest nostril
Guest nostril
:wacko: I recently had to switch off the power to my Omega 5 alarm due to a burst water pipe (two hours before a holiday) .
I powered it back on two weeks later but it had appeared to have lost the user codes. I guessed the default code as
Guest Peter James
This is because the system is defaulted completely and the system was programmed with zone 7 isolated but now its not.
Its likely that other parts of the programming like entry exit timers and bell ring timers are also defaulted to somthing nasty.
My advise would be get some quotes to put it right it probably needs a service anyway its well over 10 years old now.
Pete ;)
Guest nostril
I was hoping that someone would provide me with the information to fix it myself!!
perhaps the installers manual.
I promise I won
Guest andy jinks
if you still need some help let me know i grew up with the omega's
Guest andy jinks
strange 1 this ,,from power up and with the default loaded zone 7 should be turned off and zone 4 should be a PA button.
it maybe that the pcb has got the battery to hold the memory and it has tryed to load up but with errors.
<<PANEL DEFAULTING METHOD REMOVED>>
try this it will turn off zone 7
type 1111 enter (default engineer) you should see a flashing P
type 431 enter (zone options) shows C
type 7 enter (zone 7) shows 0
press the star untill 3 shows,if 3 is steady press ENTER (isolated)shows flashing 3
press star untill E shows ,press ENTER shows C
press ENTER shows P
type 1111 (out of engineer)
should show d
give it a go its not going to get any worse and you might get the bug.
  • 2 weeks later...
Guest nostril
Thanks Andy
All fixed now. All it needed was a factory reset.
I can't believe I didn't do that to begin with as I spotted the jumper when I first took the lid off.
thanks again
Mark
