Guest Ian Posted July 9, 2005 Posted July 9, 2005 Having problems with this alarm. two keypads work intermittently, third reads low battery. Third keypad has faint screech. Detectors not detecting? suggestions much appreciated
Guest Posted July 9, 2005 Posted July 9, 2005 Possibly a power supply problem in the main panel, usual suspect is a panel trying to charge a duff back up battery, thus causing a problem with the voltage to keypads and detectors, this situation could damage your panel also if left. Could also be a damaged/partially shorted cable somewhere, although this I would have thought would blow a fuse, but not always. Maybe you can post your location and someone on here may be able to help you??
