Guest martino Posted July 11, 2005 Posted July 11, 2005 Hi, The alarm we have fitted is an Accenta Mini and is approximately 10 years old. The alarm operates on 2 zones downstairs and a panic button upstairs. Downstairs is set on zones 1 & 2. Recently we have been getting the alarm set off when we are out and the panel shows zone 6. As far as we are aware we do not have a zone 6. Is this a reserved zone that is telling us a fault with the system or is the alarm telling us it is worn out?? Any advice would be appreciated
Guest Posted July 11, 2005 Posted July 11, 2005 Sounds like the original installer didnt programme out the zone 6 and just left the link in the panel, and the link is now loose - causing a problem. The other alternative is that they have wrongly set up zone 6 as a tamper, or should I say they havent done it correctly if that is the case.
Service Engineer Posted July 11, 2005 Posted July 11, 2005 You probably DO have a zone 6, I think you may be getting confused by the part setting options you have set up. ........................................................ Dave Partridge (Romec Service Engineer)
Guest Posted July 11, 2005 Posted July 11, 2005 It could be a faulty panel, or it could be that the panic button is wired into zone 6. With the age of the system, and also I'm assuming it's unserviced, it would probably be best to get an engineer to call and check the system over. To diagnose the cause of the fault would require access to the inside of the panel which is not a recommended end user procedure.
Nova-Security Posted July 11, 2005 Posted July 11, 2005 Accenta Mini and is approximately 10 years old. 60369[/snapback] Are you sure its a accenta mini, they are not that old www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
