Abacus 15
Having worked with these panels for a number of years i have a call pending(when the customer cames back from holiday)of the keypad constantly showing cleaner on site even though no cleaner code is in use only master and system.Personally i think the software needs changing but having not been able to go to site and restart system i wondered if anyone out there in alarmland has seen this before.
cheers The Arab
Trade Member
There must be a cleaner code in use, use the master code to scroll through and find the code set as cleaner.
60513[/snapback]
I agree check all codes i am sure you will find one set to cleaner
