Sterling 10 bell tamper
Guest crackcrime.com
Hi, I'm new here and couldnt get the search to work so will explain the problem I've got. Have a Sterling 10 panel (inherited with the house) Just had the front of the house rendered and took down the external alarm box. Just need to know which bell terminals to short out until I can get it back up again. I can choose from BT BA STB B- & B+
cheers
Gerry
B- to BT, will allow you to use the system while the bell is disconnected.
Many thanks, I've done it, just need to get around to putting the thing back up again :yes: . Great site!
