Mavrick_001 Posted July 19, 2005 Posted July 19, 2005 Hi, had sim prob on vista powerdomes with dm kit. If it's the old style joystick with the sliver stork and knob on top it's probabally a calabration problem, norbain will or should offer to send you a new type keyboard. The other problem with dm is the single telem output. If you have wired out to 1st dome, from that to 2nd 3rd etc then that should be ok. If you've star'd out to them from the dm ie 1 cable for telem to each from the dm you'll find a star driver will solve your problem, if you speak to tech they will probabally tell you the same thing. Star driver comes with lead to connect to the dm output and them the domes telem wires individually into the star driver. Come across this on a few sites, we thought it was the domes but apparently it's a problem with the dm. In doing it this way 1 dome will have to be terminated, it doesn't really matter about the termination on the others for the telem. This had sorted out our problems. Before the dome would drift up as far as it would go, other times on tours it would wounder all over the place, movement was unresponsive and so on and so forth. These things if you like kick them up the bum and make them behave, like putting a kid and rains!!!! CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
Selsport69 Posted July 19, 2005 Posted July 19, 2005 Defo the keyboard m8. VCL was bad for a while with that problem. Kev
The Arab Posted July 19, 2005 Author Posted July 19, 2005 Phoned Norbain and they told me how to recalibrate the joystick and is now much more responsive for the help and input Trade Member
