norman Posted July 18, 2005 Posted July 18, 2005 You can share my crimps and rg59. Nothing is foolproof to a sufficiently talented fool.
Mavrick_001 Posted July 19, 2005 Posted July 19, 2005 Umm would agree the way that you have been doing it the best with the loop through. It's better practice however the t's will do the job, leave the shortest termination off and the far monitor at 75ohm and it should be ok. I personally would stick with the loop through as it's "better practice" but have used them in the past when needed to add another monitor. Don't use them to split a cctv singnal from a camera as your asking for trouble, avoid this unless you are extreemly desperate as 9 times out of 10 it'll go bottoms up!!, Watch all the ropey ones now say they do it all the time!!!, I know it's the same difference but I'd personally draw the line at the monitors CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
Stealth Posted July 19, 2005 Posted July 19, 2005 I would usually use them on switcher units with BNC connections. Chubb Service Engineer
sparky83 Posted July 19, 2005 Author Posted July 19, 2005 I see so my boss is kind of right lol I was only wondering because we've been using the flat LCD computer monitors as CCTV monitors using the VGA converter boxes because they work out hell of a lot cheaper than buying flat screen monitors with built in composite connectors. Just you cant do loop through doing it this way. Only problem is that you have to keep turning on the power button on the converter everytime they switch the mains off! Trade Member
Guest Posted July 19, 2005 Posted July 19, 2005 Only problem is that you have to keep turning on the power button on the converter everytime they switch the mains off! 61463[/snapback] What a surprise, useless tat from LJD.
JB_ Posted July 20, 2005 Posted July 20, 2005 What a surprise, useless tat from LJD. 61465[/snapback] Harsh !! But fair.
ian.cant Posted July 20, 2005 Posted July 20, 2005 Ive yet to see a lcd monitor that give good picture and does the camera/lens justice. Personally a CRT monitor would be better but you would still have the same problem and for the price, well you cant whack a good old fashioned CCTV Montitor, they even come with a free loop thru connection!
sparky83 Posted July 20, 2005 Author Posted July 20, 2005 Very true ... the KOP badged ones are identical. Even the cheap BNC crimps from LJD are **** and cause more problems than you save! Trade Member
Mavrick_001 Posted July 20, 2005 Posted July 20, 2005 Seen LCD monitor at a garage today after going to a job, was very inpressed how it had been adapted with the ljd unit and picture was second to none, might be worth a lookin on these...... CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
