'Push to Set' Button
Guest jeremy_bp
Guest jeremy_bp
I need a 'Push to Set' Button for my alarm system as I want it to double up as a doorbell ;)
Having difficulty locating one, any assistance gratefully appreciated.
Im not sure that you can set up a doorbell with a push to set... I will have a look.
You could set up a zone that has a chime on it (using a Texecom control panel), and then set this to be a disabled zone in the settings. This conceivably could work.
You could allways just buy a n/c push switch from any electrical store.. cpc have a fairly good range as I recall.
D
You can double up the Push to Set button to act as a doorbell with many control panels, but this will only generate a chime noise from the control panel speaker, an external speaker or a keypad. What control panel have you got as this will determine whether it can be done..?
Guest jeremy_bp
I have a Veritas R8 Plus Control Panel and it can do it but I cannot find a 'push to set' button from any alarm suppliers.
Guest Peter James
Most distributors wont sell to the general public but if you go into a senate electrical they are attached to CSD in some way or other, they will be able to get you an ARNIE. (Terminator)
Pete :)
Guest jeremy_bp
Thanks everybody - I thought Arnie was a governor not a member of the senate (boom! Boom!)
