Guest ladyluck Posted July 21, 2005 Posted July 21, 2005 I am installing a new Optima G3 control panel and intend using a Chubb Delta 5 external siren but am not sure of the connections on the latter. My control panel terminals are T -ve tamper return A -ve supply (0V) D +ve supply (12V) B -ve sound trigger The ten terminals on the sounder are 10 str- 9 str+ 8 tamp 7 tamp 6 int batt- 5 int batt+ 4 siren 3 0V 2 + 1 siren h/off Any help with connecting this up would be much appreciated.
Mister_Dave Posted July 21, 2005 Posted July 21, 2005 Yow will find that its a gardtec delta and the connections are. T Tamp R A Tamp F And Bell hold D Siren + B siren - STRB - STR - STRB + - D There should be a internal battery to connect to INT BATT + & -. Ignore the other terminals. Dave Oxendale York based security systems engineer.
Guest ladyluck Posted July 22, 2005 Posted July 22, 2005 Many thanks Dave for the information. Does it matter which way round the T & A connections go as they are just labelled Tamp on the sounder?
Mister_Dave Posted July 22, 2005 Posted July 22, 2005 They shold be labeled Tamp F and Tamp r. If not it shouldnt matter. Dave Oxendale York based security systems engineer.
