Guest Guest_steve_* Posted July 24, 2005 Posted July 24, 2005 Would anyone know wher I can obtain the circuit drwaings for the Optima 2 plus panel. The psu has quite high ripple on it and I can't read all the values of componets. I guess this is why I am getting false alarms.
Service Engineer Posted July 24, 2005 Posted July 24, 2005 Most of the cheaper control panels don't have much DC smoothing so quite a lot of ripple is common. I actually doubt this is the cause of your problems. The TX voltage should be between 17 & 24 VAC, and after regulation the AUX voltage should be around 13.8VDC but slightly higher isn't uncommon on the ADE stuff (upto 14.4VDC Max). As for the Schematic, sorry but I doubt anyone here has one.. ........................................................ Dave Partridge (Romec Service Engineer)
Mavrick_001 Posted July 24, 2005 Posted July 24, 2005 Could ask ADE tech support, but they're neither technical nor supportive!!!, Personally, thow it away and fit something of umm how can I say.... better quality CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
Nova-Security Posted July 24, 2005 Posted July 24, 2005 If you are worried about a ripple on your panel, you could change the smoothing capacitor, easy to find next to the (LM) Rectifier. But there has been thousands of these panels sold and installed that are working alright, could it be a problem with your incommng mains or a lose connection somewhere. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest stevie p Posted July 25, 2005 Posted July 25, 2005 Thanks for all your replies. I agree with you comments about ADE although they seemed a little better before they were taken over. I have scoped the inputs and notice quite a high amount of ripple which may cause false triggering but don't know how the circuit has been designed. I may replace all the psu components whilst I look for another panel. Any good ones to consider with RKP's. Ideally need a the control part housed in a steel box hence the Optima 2 plus in the first place. Thanks again.
