Guest izzy Posted July 25, 2005 Posted July 25, 2005 after repositioning and rewiring of various pir's the entry point is set to zone 1 and i need it to be set to zone 7. any advice on how i can do this? thanks.
Guest izzy Posted July 25, 2005 Posted July 25, 2005 i was hoping for a programatic way of doing it. but failing that i will try swapping the sensors which should work. thanks buddyboy.
Guest Posted July 25, 2005 Posted July 25, 2005 Not the sensors, that won't make any difference. The zones in the panel.
Guest izzy Posted July 27, 2005 Posted July 27, 2005 sorry mate, thats what i meant. i did swap the zones in the panel and it worked. thanks for your help.
Mavrick_001 Posted July 27, 2005 Posted July 27, 2005 Another satisfied customer!!! CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
