MELCOM AD1000 VOICE DIALLER
Guest glangarnant
Guest glangarnant
Anyone know how to change Tel 1 number from User Option ?
Manual states :
Enter Code press PROG ENTER
But this only removes the number.
THe same "process" is shown on the manual to Display Tel 1 Number.
So............. Suspect the manual has a printing error.
Contacted Lynteck & Melcom but v e r y s l o w replying.
Bernard
Engineer options work fine.
Guest glangarnant
Heck !! Am I the only one using the Melcom AD1000 ??
62776[/snapback]
Most probably.
Guest glangarnant
Hopes were good when I saw reply !!
When read I went back down in the pit !!
Thanks Lurch
  • 3 years later...
Did you ever get a reply? Answer to your question is user code [PROG] telephone no [ENTER]. Took me a while to figure it out too. I've had the system a while but only just needed to change thenumber.
