sl compact
Guest mandi
Guest mandi
moved into a new house we have an sl compact alarm no manual!
does anybody now how to turn off the chime which is at a floor level sensor (back door)? driving us mental
Press "CHIME" button, the day indicator will go off and a RED light above any chime enabled circuits will be displayed above the corresponding enabled zone, to cancel the chime press the corresponding number on the keypad and the light will extimguish. Then press "RESET" and away you go.
Manual attached in PDF format. Not a very good copy but will give you some information on your system.
SL8_user_GUIDE.pdf
