"From Technical Terms to Kit List...."
Guest Dobbin
You have 2 zones in each keypad+ 8 in panel=12, just needs a 12 core to each keypad.
Guest Dobbin
cheers Glen.
I don't need an expander after all.
Do I need the 12 core from the keypad to the control panel or the control panel to the device?
What core cable do I need generally?
By the way I got a good quote from Alert but a great quote from Safedirect.
Dobbin
Either wire devices to the keypads in 8 core or wire them all to the control panel and join them at the control panel to a 12 core going to the keypad using 4 cores for the keypad and the other 8 to carry the 2 zones and tampers.
Guest Dobbin
Got that Glen
Thanks
Dobbin
Guest Dobbin
Just working out where to place the sensors and I need some more advice. Can a sensor be placed in a south facing conservatory or will it get too hot and cause a malfunction (or false alarm)?
If yes what sort of sensor would be best?
Dobbin
Dobbin
63332[/snapback]
A dual tech detector is probably your best bet for a conservatory. That way, the temperature won't really affect it if it has been set up properly. You could also go with a few shock sensors on the window frames, but because there are so many possible points of intrusion in a conserv, volumetric (ie a dual tech) is probably your best bet.
Trade Member
definitely a dualtec.
Zak Tankel - Managing Director - Security First (UK) - www.securityfirst.uk.com
Disclaimer: Any comments or opinions expressed by me are my own as a member of the public and not of my employer or Company.
Make sure it also has a white light filter.
Guest Dobbin
I am planning on using the Texecom Mirage Dual Tech Sensor.
I have checked the brochure on the Texecom website but I cannot see any reference to White Light Filter.
Anyone know if this Sensor has a white light filter?
Dobbin
Dobbin
63530[/snapback]
Got one in my conservatory, never had a false alarm yet
