Veritas Tamper fault
Guest stevep
Guest stevep
Hi
I have a Veritas control panel, I think R8, (fitted around 1999) which has suddenly developed a tamper fault. I have not been decorating or changing anything and the system seemed to develop this when we popped out yesterday afternoon.
Have tried all the usual, reset and have also turned mains power off.
I have found that I can still set the alarm only if I omit Zone 9 - which is odd as I don't think there is a zone 9!
Can anyone help on this.
I wasn't sure whether it was the automatic service reminder?
cheers
Guest stevep
Am I right that these systems have an automatic service reminder. Would this set the tamper light when due?
Am I right that these systems have an automatic service reminder...
63061[/snapback]
It has to be set by the installer, and to be honest, not many do set them up.
Trade Member
Zone 9 is effectively the global tamper. Could be a cable fault, bell fault, panel fault or a tampered item on the system. Make sure all the covers on the PIRs, speakers, keypads, panel are on tightly before you try to make any other diagnosis.
Guest stevep
Tried this - still showing red tamper light.
I think I might have to call out an engineer.
AXL Security are the people who installed so might as well call them.
Thanks
Steve i take it your in north yorkshire. They used to fit the ade sonade wich caused intermittant tamper faults so most of there boxes have to be changed.
Dave Oxendale
York based security systems engineer.
