chris j Posted August 1, 2005 Posted August 1, 2005 Does anyone know if any of the on board outputs on a Galaxy 60, if programmed, E/E horn will drive a speaker to follow the entry/exit tones of the RKP for each group (2 groups, 2 RKPs', one on each floor of the building).
black knight Posted August 1, 2005 Posted August 1, 2005 Does anyone know if any of the on board outputs on a Galaxy 60, if programmed, E/E horn will drive a speaker to follow the entry/exit tones of the RKP for each group (2 groups, 2 RKPs', one on each floor of the building). 63070[/snapback] If i follow correctly what you're asking yes they will. the o/p's are voltage driven tho so you will need a speaker with a driver board. Program the o/p then to a group and hey presto. paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
chris j Posted August 1, 2005 Author Posted August 1, 2005 If i follow correctly what you're asking yes they will.the o/p's are voltage driven tho so you will need a speaker with a driver board. Program the o/p then to a group and hey presto. mate 63073[/snapback]
gla.ssfp Posted August 1, 2005 Posted August 1, 2005 If i follow correctly what you're asking yes they will.the o/p's are voltage driven tho so you will need a speaker with a driver board. Program the o/p then to a group and hey presto. paul 63073[/snapback] Thats interesting, In that case you could switch off the RKP tones and just use the speakers? I have a similar situation, been meaning to ring technical for ages I have 4 groups set up on my own system but at the moment all RKP's bleep when you are entering or setting which is somewhat anoying Do you have any part No.s for the correct speakers?
Guest Posted August 1, 2005 Posted August 1, 2005 Thats interesting, In that case you could switch off the RKP tones and just use the speakers?I have a similar situation, been meaning to ring technical for ages I have 4 groups set up on my own system but at the moment all RKP's bleep when you are entering or setting which is somewhat anoying Do you have any part No.s for the correct speakers? 63080[/snapback] prog each rkp e/e o/p to a group or groups you dont need extra spkrs..
black knight Posted August 1, 2005 Posted August 1, 2005 Thats interesting, In that case you could switch off the RKP tones and just use the speakers?I have a similar situation, been meaning to ring technical for ages I have 4 groups set up on my own system but at the moment all RKP's bleep when you are entering or setting which is somewhat anoying Do you have any part No.s for the correct speakers? 63080[/snapback] not of top of my head but gardiners will stock them. there is I remember (or at least there used to be) a sounder which has two inputs for low and hi onto a driver board which feeds a speaker which is a easy way to use a the same sounder for entry exit and alarm sounder prog each rkp e/e o/p to a group or groups you dont need extra spkrs.. 63100[/snapback] quoted for agreement paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
gla.ssfp Posted August 2, 2005 Posted August 2, 2005 prog each rkp e/e o/p to a group or groups you dont need extra spkrs.. 63100[/snapback] I cant beleive I missed that Well it has been a while since I did my training Just went straight to it on galgold Oh well another job on my list !!!
