ant_cctv Posted August 6, 2005 Share Posted August 6, 2005 Has anyone managed to get an ljd (vido) ptz dome camera working with geovision? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/7015-vido-ljd-dome-with-geovision/ Share on other sites More sharing options...
Guest gerardcraggs Posted August 6, 2005 Share Posted August 6, 2005 I dont think that camera is supported by Geovision, as far as I am aware the only PTZ cameras supported by Geovision are: 1. PTZ in I/O 2. Canon VC-C3 3. Canon VC-C4 4. Pelco/P-version Protocol (Spectra series) 5. Pelco/D-version Protocol 6. Ademco (Juptier) 7. LiLin PIH-7000 (17X) 8. LiLin PIH-7600 (22X) 9. LiLin PIH-7625 (25X) 10. DiGi Dome (DOH-240) 11. DynaColor D-7720 12. DynaColor D-7722 13. Sony EVI-D100 14. Sony EVI-D100T 15. Panasonic WV-CS850 16. Panasonic WV-CS854 17. Mintron (54G2AHN/P) 18. Kalatel Cyber Dome 19. Samsung (SPD-1600) 20. Sensormatic (Ultra IV) 21. Samsung (SCC-641) 22. Samsung (SCC-643) 23. Hi-Sharp (HS-CC600) (use Pelco-P protocol, Baud Rate 9600) 24. Elitar (EL-PT830) (use Pelco-D protocol, Baud Rate 2400) Regards Gerry Link to comment https://www.thesecurityinstaller.co.uk/community/topic/7015-vido-ljd-dome-with-geovision/#findComment-63589 Share on other sites More sharing options...
hastings Posted August 7, 2005 Share Posted August 7, 2005 Is that all ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/7015-vido-ljd-dome-with-geovision/#findComment-63670 Share on other sites More sharing options...
ant_cctv Posted August 8, 2005 Author Share Posted August 8, 2005 The PTZ can use the pelco p + d and some other protocols. If i set geo and the camera to the same protocol should it work? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/7015-vido-ljd-dome-with-geovision/#findComment-63763 Share on other sites More sharing options...
Guest gerardcraggs Posted August 8, 2005 Share Posted August 8, 2005 In answer to your question, if you ring EZcctv (0870 609 4507) they should be able to tell you the answer. A more up to date list is below. 1. PTZ in I/O 2. Canon VC-C3 3. Canon VC-C4 4. Pelco/P-version Protocol (Spectra series) 5. Pelco/D-version Protocol 6. Ademco (Juptier) 7. LiLin PIH-7000 (17X) 8. LiLin PIH-7600 (22X) 9. LiLin PIH-7600PL 10. LiLin PIH-7625 (25X) 11. DiGi Dome (DOH-240) 12. DynaColor D-7720 13. DynaColor D-7722 14. Sony EVI-D100 15. Sony EVI-D100T 16. Panasonic WV-CS850 17. Panasonic WV-CS854 18. Mintron (54G2AHN/P) 19. Kalatel Cyber Dome 20. Samsung (SPD-1600) 21. Sensormatic (Ultra IV) 22. Samsung (SCC-641) 23. Samsung (SCC-643) 24. Hi-Sharp (HS-CC600) (use Pelco-P protocol, Baud Rate 9600) 25. Elitar (EL-PT830) (use Pelco-D protocol, Baud Rate 2400) 26. JEC (ETXK8000) (use Pelco-P protocol, Baud Rate 4800), Not Support: AUX, Frame Scan and Random Scan) 27. MZC-IR6018DN (use Pelco-P and Pelco-D protocol) Not support: Home, Focus In, Focus Out, Aux, Auto(Auto Scan, Frame Scan, Random Scan) and PTZ Speed. 28. YOKO YE-2E00 (use Pelco-P and Pelco-D protocol) Not support: Aux, Frame Scan, Random Scan 29. SAE DR-E588 30. Kenko DMP23-H1 31. DPerception PTU-D46 32. TOA cc551 33. ELBEX 34. JEC 35. CPT-V9KRV 36. Minking 37. YAAN 38. ZC_S122 39. KZC 40. Bosch TC8560 & TC700 Regards Gerry Link to comment https://www.thesecurityinstaller.co.uk/community/topic/7015-vido-ljd-dome-with-geovision/#findComment-63771 Share on other sites More sharing options...
