Guest Stevenselby Posted August 7, 2005 Posted August 7, 2005 Hi All Does anyone have a terminal function diagram for the XPC trigger module - I know this is used to communicate with redcare stu's but I want to use it to give individual outputs for alarm, PA and fire - is this possible. Thanks
jb-eye Posted August 7, 2005 Posted August 7, 2005 Hi AllDoes anyone have a terminal function diagram for the XPC trigger module - I know this is used to communicate with redcare stu's but I want to use it to give individual outputs for alarm, PA and fire - is this possible. Thanks 63651[/snapback] Im oviously out of touch, i thought xpc only had one prog trigger output. Customers!
JB_ Posted August 7, 2005 Posted August 7, 2005 It's available from the ademco tech tips section. HERE
