Veritas compact problem
Guest Ian
asked to reprogram veritas compact (entry/exit timers too long. The panel has been locked out (no factory reset possible, power down - no probs talking to installer)
The nice old lady asked if i could change the user code- no probs i thought.....
the panel will not except a new code. followed manual. all i get is annoying harsh buzz
any help is much appreciated as ever
cheers
Ian :huh:
You sure her existing code is working? Unset LED should flash if it is.
You've probably tried this already but procedure should be CODE, PROG, 60, NEW CODE, PROG, RESET
Other than that you may need to contact an engineer to look at it
Mark Hawks
Ex BT Openreach Field Service
Or you may have a pre2000 panel.
Hmm my knowledge of pre 2000's is somewhat hazey
Mark Hawks
Umm.. CODE followed by 00 (all lights on) 01 (zone 1-4 lights on) NEW CODE then RESET. If i rememeber correctly.
The panel is pre 2000, cheers will try suggestions
Ta
64350[/snapback]
Close! Its right up until new code then -PROG- then reset.
