Guest Posted August 17, 2005 Posted August 17, 2005 Some panels have "electrical fuses" that just limit the current draw. in that case i just change the detector. otherwise i remove correspondent fuse but leave the panel itself alive.
ian.cant Posted August 17, 2005 Posted August 17, 2005 How do the Pro's do it? To the sound of bells sirens and buzzers B) Its always advisable to not work on anything that is live, electrically speaking. I would suggest its best to remove the relevant fuse or isolate the relevant supply, then make your connections, restore the power and Bobs your uncle so to speak. Reality is when dealing with low voltages (12v dc or 24v ac) we are most likely to do it live, but thats because we do do this every day of every week etc........ My advice is do it with power removed, safer all round.
djrock Posted August 17, 2005 Author Posted August 17, 2005 To the sound of bells sirens and buzzers What about strobes? My advice is do it with power removed, safer all round. Remove the 240 volts from the panel or just to remove the fuse or the wires that supplies the 12 volt to the pir's? I would probability remove the positive wire of the pir i am working on. thankyou djrock
chris j Posted August 17, 2005 Posted August 17, 2005 What about strobes?Remove the 240 volts from the panel or just to remove the fuse or the wires that supplies the 12 volt to the pir's? I would probability remove the positive wire of the pir i am working on. thankyou djrock 64950[/snapback]
Guest Posted August 19, 2005 Posted August 19, 2005 What about strobes?Remove the 240 volts from the panel... ... djrock 64950[/snapback] in that case also the battery..
Guest G.J.M Posted August 19, 2005 Posted August 19, 2005 but leave the panel itself alive. remind me never to fit the type you are using as i would worry it may get up and walk out the house one day.
Guest Posted August 19, 2005 Posted August 19, 2005 remind me never to fit the type you are using as i would worry it may get up and walk out the house one day. 65120[/snapback] don't worry. panels dont walk to your dreams if you install them properly..
djrock Posted August 23, 2005 Author Posted August 23, 2005 Hi, I think I will keep the panel alive. Unless its advisable to remove all power from it. What are the signs of the panel being alive when there
Guest Posted August 24, 2005 Posted August 24, 2005 Hi, I think I will keep the panel alive. Unless its advisable to remove all power from it.What are the signs of the panel being alive when there
