False alarms
amateurandy
I would have a serious look at your system this is way to high in the first place, a high value would be 5 to 9 volts but 15v somthing needs looking at.
66074[/snapback]
Interesting; any suggestions what to look for?
I know for a fact that none of the alarm cables run parallel or close to any mains power around the house, and only a couple cross lighting cables at right angles between the joists. The power to the unit comes in from below and everything else leaves going up.
Could it be a faulty power supply? There just seems to be a transformer which provides what I would guess is low-voltage AC output to the main PCB; presumably conversion to DC is on the same single board as everything else?
It's an ADE Accenta G3.
66074[/snapback]
Never checked a Veritas then? I constantly find around 10-18v with no real adverse effects. I would personally only clamp it down if it was having fa's though.
I wouldnt be too worried about it andy, keep the filter fitted and you should be ok.
