Guest thedarklord_zero Posted August 20, 2005 Posted August 20, 2005 hey there i been reading the Veritas 8c installion manual and does the engineer have a extra pin lets say my pin is 9685 and a engineer comes does he enter a differnet pin? , luke
gooner31 Posted August 20, 2005 Posted August 20, 2005 you are correct you will have the master or a user code. The enginer has his own code pete ................. Any comments/opinions posted are my own and not that of my employers.
Guest Posted August 20, 2005 Posted August 20, 2005 usually there are _at least_ three MAINLY different code types in systems: USER = SET/UNSET MASTER = SET/UNSET+OTHER FUNCTIONS ENGINEER/INSTALLER = OTHER/ENGINEER FUNCTIONS some panels have different levels for user codes. and PIN's 99,99% differs from each others..
Guest Posted August 20, 2005 Posted August 20, 2005 i suggest that you get a proper engineer there to reset your panel. post your location and someone will be found for you.
Guest thedarklord_zero Posted August 20, 2005 Posted August 20, 2005 lol so you have to watch the enginer when he comes out thanks for your help luke
Guest Posted August 20, 2005 Posted August 20, 2005 possibly im lost in translation again (or rest of you are ) but i hope you don't have to watch engineer to come out from a closet..
Guest thedarklord_zero Posted August 20, 2005 Posted August 20, 2005 i mean you have to watch the enginer when he comes out (entering his pin)
JB_ Posted August 20, 2005 Posted August 20, 2005 anyway of findin it out? 65254[/snapback] Of course there is, simply tap out the numbers and add 1 each time. 0001, 0002, 0003, 0004, 0005 alll the way to 9999, what could be simpler. Ever wondered why your calls out seem to take forever? The engineer's simply forgot the code and is doing the exact procedure above. * * Events described in this post are make believe and may not have actually happened
