Veritas 8c
Guest thedarklord_zero
i am not that thick lol
:P
Of course there is, simply tap out the numbers and add 1 each time.  :P
* Events described in this post are make believe and may not have actually happened
65260[/snapback]
i can assure it has happened.. reason why i know almost all engineer codes here in coldshire.. :whistle:
i want the enginer code for my alarm :cry:
65266[/snapback]
you can't get that from here (this site). you need a proper engineer to sort it out.
maybe you post your location so we could suggest a proper engineer close to you..?
:question:
lol dont think that would worl but leeds :unsure:
just wait for a bit. someone will post the info dor you quite soon i believe.
edit:
( meanwhile i go to see from the map where in the h**l leeds is.. :whistle: )
its in west yorkshire
don't have a slightest idea where that is but if i am not too wrong Pete (situated in wakefield) is quite close to you (from my view.. :D)
