Alarm for my new house
Guest SteveOh
Guest SteveOh
Hiya fellas.. excellent forum......
I'm buying a new house and need to fit myself an alarm, it's been a while so any help is appreciated
I like the look of the Texecom Premier stuff... any good?
here is my list so far:
Premier 24 panel
keypad with "Proximity tab"
Texecom dual tech detectors
Digicom PCOM300
Texecom Odyssey 3 115db triangular External Sounder
internal sounder
battery
cable
magnetic contact for front door
fuse spur + bit of twin and earth
Thanks for any helps fellas
Guest roonster
flex to take from spur into box.
Digicom PCOM300
65533[/snapback]
Do you actually need a digicom? Do you know what they're used for?
Guest SteveOh
@JB..... Digi is to tell me when my alarm is going off..... the one ive specced will SMS me... (i hope)
By Internal Sounder do you mean the likes of a sound bomb. I wouldn't bother. I'd just put an extension speaker on the panel. Plenty loud enough if you ask me.
Trade Member
The com300 you've speced won't do sms, only the com2400 does it.
Mark Hawks
Ex BT Openreach Field Service
Guest IM_Alarms
Have you got any experience in alarm install? As it is a couple of steps above diy, with the combination of kit you are choosing, but it'll be a nice home system if you give it some thought and care in your installation.
Good Luck :yes:
you would be better off with a sd2 speech dialer it also sends sms ( i think )
65551[/snapback]
Your right Whistle. SD2 does sms
cheers Kev
65551[/snapback]
As does the Texcom Speech and Text dialler... ;)
Thanks,
Mark
