What is O/P
djrock
Hello, What is O/P? In the Programming manual the options are PIR set latch and Shock reset. What is it used for, how to use it and what do the different options do?
Thankyou
djrock
O/P is output and this one is programmable.
When it is set as PIR set latch it provides +12V to the latch terminal of PIR's when set as when you wire multiple PIR's on one zone (not recommended) the LED remains on on the PIR(s) activated so you know which one triggered the alarm, or some similar variation.
Shock reset is pretty much the same and is wired to the terminal on compatible shock sensors to reset the unit after an alarm condition.
What panel is this for?
Hello, Thankyou Lurch for answering my question. I don't like giving out what panel I have. I don't think I will be using the o/p I was just wondering why it was supplying 12 volts.
Thankyou
djrock
Hello, The alarm is not a Optima compact. What other uses can you use o/p for that Lurch has not mentioned?
Thankyou
djrock
Depends on the panel and what you want to do, the below is a list of what the outputs on the panels we use can be use for, like turning a light on and off on the entry route. But due to not knowing what control panel you have nobody can advise you, also these outputs are not on all panels.
01 Final
02 Exit
03 Intruder
04 24 Hours
05 Security
06 Dual
07 Entry
08 Push Set
09 Keyswitch
10 Secure Final
11 Part Final
12 Part Entry
13 PA
14 PA Silent
15 PA Delay
16 PA Delay Silent
17 Link
18 Spare
19 Fire
20 Tamper
21 Bell Tamper
22 Beam Pair
23 Battery Low
24 Line Fail
25 AC Fail
26 Log
27 Remote Access
28 Video
29 Video Exit
30 Intruder Delay
31 Log Delay
32 Set Log
33 Custom-A
34 Custom-B
35 Exitguard
36 Mask
37 Urgent
38 PA Unset
39 Keyswitch Reset
40 Bell fail
41
www.nova-security.co.uk
www.nsiapproved.co.uk
That'll be the big G then nova :P
BTW dave is sending me those bits over the weekend so i'm ready when you are.
Regards
Bellman
