Guest LED Posted September 6, 2005 Posted September 6, 2005 I have recently installed a pyronix sterling 10 pannel. Sounders are texecom odyssay 1e Twin pezzo After the installation I was encountering a tamper fault when setting the panel. When not set the tamper fault did not show, only when setting. I have followed texecom wiring of 2 bell boxes together. I did mangage to rectify the fault by linking the sterling 10 panel bell box connections 0v and bell tamper. can any one suggest if I have to supply a link inside one of the sounders 0v to bell tamper. Regards LED
gooner31 Posted September 6, 2005 Posted September 6, 2005 No you dont if you have linked the tamper out in the panel it should be ok.does it set ok now. pete ................. Any comments/opinions posted are my own and not that of my employers.
