norman Posted September 10, 2005 Posted September 10, 2005 I cant remember where I read it but it has been suggested (if not proved I'll see if I can dig it out) that having another person footing a ladder is no use whatsoever. Nothing is foolproof to a sufficiently talented fool.
Truss and France Posted September 10, 2005 Posted September 10, 2005 If you contact your local HSE office they will send you a leaflet on the current regulations, they might even be on the web. From what I can remember they are pretty ridiculous i.e should not work above 2m of steps or ladders, a tower should be used. However you would think if they really wanted to inforce H&S then steps and ladders should be banned.
norman Posted September 10, 2005 Posted September 10, 2005 An uncle of mine was a linesman with the local electricity board, he told me a story of a colleague being at the bottom of a ladder when the guy at the top shouted to him, not hearing what was shouted he looked up...to get a pair of heavy pliers through the eye socket. Nothing is foolproof to a sufficiently talented fool.
black knight Posted September 10, 2005 Posted September 10, 2005 We have to call another Engineer to come and assist, if he isn't available at that time we are supposed to re-book the job and attend at a time when we will both be available. This applies to every instance when working above 2 Meters. 67690[/snapback] christ if i did that i would,nt get any work done! on a average day i must get my ladders up tp cameras at least once. Methinks i will check at office what we are supposed to be doing. paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
Nova-Security Posted September 10, 2005 Posted September 10, 2005 They were discussed in THIS Thread.Regards Bellman And Here http://www.thesecurityinstaller.co.uk/comm...wtopic=5596&hl= www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest Posted September 10, 2005 Posted September 10, 2005 I use these Combi-Ladders. At the moment though, no harness. 67676[/snapback] thats not you dave..he only looks about 39..
Guest IM_Alarms Posted September 10, 2005 Posted September 10, 2005 I dived out of the way of a brick that had been grabbed for support by the guy climbing the ladder, which had come off the top of the wall, he swung his arm round to regain balance, launching the brick straight for my head as I footed the ladder. I do not think the bottom of a ladder is a good place to be at ANY time. Although I was always under the belief that no electrical trademen could work alone, due to the possibility of electric shock. It's unreasonable to expect a passer-by or shop assistant to come to your aide whilst hooked up to some voltage. They just wouldn't know where to start!
jb-eye Posted September 10, 2005 Posted September 10, 2005 I posted this link a while back. Alarm engineer injured What i would like to say is the firm involved is a good company and this incident could have been anyone one of us as we have all been there, but as things are today, someone has to take the blame. Jef Customers!
Anusoflannigan Posted September 11, 2005 Author Posted September 11, 2005 I guess it is better to be safe than sorry I also believe that there is a section which basically says to use your common sense. ie if it takes longer to drill an eyebolt and secure yourself to it, than it would to put up a decoy or adjust a camera, then it would seem practical to do the job and get down to safe ground asap. The ladders still have to be fully secure to create a scaffold/ secure structure to work from, unless you work under 2 metres...
PJF Posted September 11, 2005 Posted September 11, 2005 We get regular talks on the use of ladders,the usual stuff about three points of contact but im still expected to fit to a bell off them. I always say its impossable but then I was told your knees count as two of the contact points . Dave, the picture of the guy on the A frame ladders is using them wrong as you are not ment to go past the top of the A. Several months ago we were told about the eye bolts but has anyone been to a job and found one?. Whos job is it to fit this, and how long before they bring out a reg on load testing the eye bolt . Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
