Guest spykid Posted September 12, 2005 Posted September 12, 2005 Hi,could anyone offer there advice,after a powercut optima xl6 does not function correctly,I cannot set or reset the alarm although there is power evident 2 led's power/zone 1 are lit up, regards Mark..
bellman Posted September 12, 2005 Posted September 12, 2005 Your back up battery is faulty and needs replacing. It should be changed every 4 years at a bare minimum. The panel will need power cycling and a new battery but you need to check to make sure the charging cct is functioning correctly as duff batteries have a habit of cooking the charging cct on these panels. Hope this helps Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest Posted September 12, 2005 Posted September 12, 2005 Your back up battery is faulty and needs replacing.It should be changed every 4 years at a bare minimum. The panel will need power cycling and a new battery but you need to check to make sure the charging cct is functioning correctly as duff batteries have a habit of cooking the charging cct on these panels. Hope this helps Regards Bellman 67879[/snapback] getting into training mode for your new job chris..
bellman Posted September 12, 2005 Posted September 12, 2005 Always in "training" mode me geezer. I find a large lump of 2" X 4" affectionately known as a "clue x four" helps in certain situations though See HERE for a fuller explaination. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
