false alarms
Guest adrian64
Guest adrian64
we have a veritas 8c alarm installed in the house and just recently it has started going off for no reason . can anyone help cheers
Er, well, ????
Some more info would be useful, like what zone's are setting the alarm off, what does go off, (i.e. internasl or external sounders), what indicators come on on the keypad, when was it last serviced, are you in or out when it goes off, what are you doing when it goes off.
Er, well, ????
67966[/snapback]
Agree with Lurch there its abit like saying"I have a piece of string in my pocket how long and what colour is it?"
Paul :yes:
Paul :yes:
67975[/snapback]
Is it white? Umm... 8cm x 12cm? Do i win anything? ;)
its twice as long from one end to the middle,available in assorted colours..
now give me my prize.. :P
Eng and JB..
are you talking about which pocket at the moment..?
:question:
67965[/snapback]
If you can't see anything obvious (insecure doors/windows, something that may move in front of a detector), then I'd recommend you get someone out to look at it for you.
Click on the 'installers' link at the top of the page to find someone local to you.
If you don't know......ask.
  • 3 months later...
If it is pir sensor zones that are causing the alarms then I would check inside the sensor as small spiders or flies sometimes get in and set the system off.This has happened to me a few times in the past.
Xmas decorations in front of a sensor?
