Guest dfalconer Posted October 24, 2003 Posted October 24, 2003 I have a burglar alarm system in the house. It was fitted by a previous owner and i dont know the activation code. It is pretty old and the sensor wires look a bit tired. If i cut the wires to the sensors will the alarm go off. The alarm is not armed at present. Also how do i cut power to the alarm safely.
FASTCAR Posted October 24, 2003 Posted October 24, 2003 If you cut the wire , the internal alarm will sound , and you will probably blow the aux12v fuse.......you 're not a burglar are you? Browse for the post on decommissioning , it may help.
Guest dfalconer Posted October 24, 2003 Posted October 24, 2003 if i was a burglar i would be an extremely bad one clearly i will search
