Panel Tamper
Guest funkyman
Guest funkyman
I have an Aritech CS350 panel which is showing a panel tamper constantly. I have held in the tamper button manually and it still shows and have carried out a continuity test on the button which seems to work (the two pins on top link to the two pins on the bottom when the button is pressed and the two top pins and two bottom pins are always connected)
Is there any way to disable the panel tamper or check if the switch may be faulty.
Will a reset to factory settings do anything except delete all the programming I have done?
Thanks in advance for any help.
68533[/snapback]
offer a little more info such as: is this a new instal has the panel ever worked. Panel tamper on aritech dosent just include the panel it is PROBALY something else. Try the RKP, but my bets on the outside warning device
My mistake boys i didnt realise this was a blue forum or i would not have replied
Jef
Customers!
Guest funkyman
I found the problem: The Panel Tamper must be looped with the Auxiliary Tamper. I linked out the Aux Tamper in the panel and the message disappeared once I closed the panel. The problem I have now is finding the break in the tamper loop...
Thanks for the reply.
Guest graale00
If in doubt, link it out, but make sure somebody is called to sort the tamper problem as soon as possible.
69040[/snapback]
Err, linking out like that is a bad idea since the cable and device that is attached to it is now no longer protected.
Say for example this was a SAB tamper that had gone high resistance because the tamper switch had corroded so you link it out.
what then happens when it starts ringing at 3AM because you didn't repair the switch?
Tamper faults can also indicate damage to wiring for example cables chewed by rodents, so you link it out and that night mr mouse comes back and chews a bit more thus causing a false call to the police. :no:
Better to fix it now. It's a cheaper and better solution for all concerned. :)
Granted some situations may warrant its use as a diagnostic aid but temp repairs like that have a habit of becoming permanant.
Regards
Bellman
Regards
Bellman
69090[/snapback]
a cat will sort the mouse out..unless its called tom and the mouse is called jerry...stupid cat....thats sounds like something :hmm:
LOL @ Gaz
Tamper faults to Tom & Jerry, this forum has it all ;)
LOL @ Gaz
Tamper faults to Tom & Jerry, this forum has it allĀ  ;)
69100[/snapback]
i thought the cat was a good idea... :bird: :bruce_h4h:
You and your pussy fixation again.
05 30 36 :whistle:
Regards
Bellman
