secomandy Posted September 22, 2005 Posted September 22, 2005 code + 4 is code change isnt it,, 69045[/snapback] quite right i must be loosing it the button is omit not number 4
secomandy Posted September 22, 2005 Posted September 22, 2005 when you open the garage door there should be the fault light on, with the zone number preceeded by C (C8 for example)thats the zone number.
Guest Newts Posted September 23, 2005 Posted September 23, 2005 when you open the garage door there should be the fault light on, with the zone number preceeded by C (C8 for example)thats the zone number. 69166[/snapback] Thanks for your info. I will check it tomorrow
