A1 Omnicron 8000
Guest nickward
Guest nickward
Is it possible to obtain user instructions for the above panel and possibly even engineers guide I am currently replacing external bell box on this system and would like to test system afterwards.
I have also just read somewhere that they would not recommend making any modifications to this type of alarm panel, would this be the general consensus ?
Regards
:sign:
Regards
:sign:
69073[/snapback]
I dont think there are a proper set of engineer instructions around for that panel, i know i couldnt find any last week. Why would you need engineer instructions though to test the bell?
Set the system and activate a sensor would normally work fine?
The only modifications I would make to this panel would be of the throwing it in the bin variety tbh.
I believe user code then 3 is test siren and strobe and 3 to stop.
Guest nickward
I wanted eng instructions just in case anything goes wrong. Like to have all info possible prior to starting job :fear:
Guest nickward
69076[/snapback]
Thanks for the advice, may well be throwing it in the bin yet if it proves a problem. I tend to get the impression that this panel left a little to be desired even when it was new !!!
:signthankspin:
Omnicron panels have to be the worst cheapest rubish i have ever had to work on. :Booty:
Ditto,
You'd devalue the bin if you threw it in there.
Ditto,
69310[/snapback]
Agreed anyone fitted their speech diallers, super ****!!!!!
Trade Member
I am ripping out a omnicron tomorrow and fitting a scantronic 9651.
Any offers for it ? LOL
you might get a few quid for the manual, by the sounds of it.
