Guest mark/rachel Posted September 22, 2005 Posted September 22, 2005 help wanted i have a veritas 8c panel it was working fine until i took one of the pirs out and the other three pirs wont work at all now they wont light up etc can anybody help me ms121062@ntlworld.com
Guest Santa Claus Posted September 22, 2005 Posted September 22, 2005 Oh dear! it sounds as though you have blown a fuse, Get your maintenance company to check it for you.
Guest mark/rachel Posted September 22, 2005 Posted September 22, 2005 i have checked all fuses they are all ok thanks
Monteey Posted September 22, 2005 Posted September 22, 2005 Even the fuses inside the panel? Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest mark/rachel Posted September 22, 2005 Posted September 22, 2005 yes i have checked all fuses in the panel they are all ok thanks
bellman Posted September 22, 2005 Posted September 22, 2005 In that case check the aux output to see you have at least 12volts dc there, if not and the fuses are ok you've cooked the panel. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest mark/rachel Posted September 22, 2005 Posted September 22, 2005 i have taken front cover off and checked the output there is nothing there all fuses are ok thanks
bellman Posted September 22, 2005 Posted September 22, 2005 In that case check the aux output to see you have at least 12volts dc there, if not and the fuses are ok you've cooked the panel.Regards Bellman 69212[/snapback] Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
bellman Posted September 22, 2005 Posted September 22, 2005 Incidentaly, have you checked for voltage with a multimeter at both ends of the fuses by using the red lead whilst black lead on -ve? Not trying to sound patronising but i've come accross several duff fuses that visually looked ok. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
dpaengineer Posted September 22, 2005 Posted September 22, 2005 Only other thing i can think of is if the 12v and 0v powers where wired radial from 1 device to the next and you have removed the 1st device. How many wires were in the 12v 0v terminals in the PIR? 1 / 2? Though i must add that this would be a very daft way of doing it Trade Member
