Accenta 8
Guest crx3510
Guest crx3510
I have purchased a house fitted with an Accenta 8 (not the mini),now the previous owners tellme that they never had a code or never used the alarm, a bit odd however i would like to set thealarm but do have the code, so how do i reset it so i can program my own code,also isthere a manual out there? thank u.
If the system is powered up try 0123 or 1234.
If these dont work I would suggest that you contact a local alarm company and get them to check the system over and deafult the system and they will set it up for your own requirements.
Colin.
