Non switched fused spur... you knew it would come!
Guest John C
I'm installing a non-switched fused spur.
Just wondered if anyone had any recommendations on type of box and manufacturer?
cheers.
box as in back box or the spur unit?
box=any make is fine.
Spur= MK, Ashley are good.
IF you buy the box and spur from same manufacturer they look better as they are made for each others shape.
MK everytime :yes:
Mark Hawks
Ex BT Openreach Field Service
MK everytime :yes:
69387[/snapback]
QFA..
IT's simply safer to say MK :P
The cheapest i can buy as they all do the same job. if i get a mk it would cost twice as much as a B&Q cheap one and it still holds a 3amp fuse.
69402[/snapback]
so you drive a 20yr ols skoda then,listen to a wireless etc..still does a job :bird:
no class :P
