Break glass detectors
Guest Rocky
Not convinced these break glass detectors are worth the hassle.
I struggle to get around 50% of them to activate and most of the ones I do activate only work if I hold the test piece (an electronic break glass simulator resembling a table-tennis raquet) right up against them.
I think I've only ever seen 2 or 3 that I've managed to trip from the extremes of the room, i.e. as far from the detector as possible.
What do the rest of you think...
69424[/snapback]
right place right time there good....but it still make me :ranting: when i see them fitted in windows which have shutters..
69425[/snapback]
Agreed in a town centre with loads of p!ss heads kicking the shutters Yet another call out for no reason, Argg
69424[/snapback]
they dont usually have a range of more than a few meters - maybe the area you are testing needs more detectors.
If its in the kitchen slamming the knife and fork drawer is a great way to test it. Gets mine every time. :whistle:
I always found jiggling your keys is a good way to test them :)
Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
69547[/snapback]
QFA and that is what worries me about them and why I dont like them.
I dont think they are something you would fit from choice only if it was an insurance or customer requirement they always seem a bit hit and miss to me with different types of glass behaving in so many different ways frequency wise I would prefere a disclaimer in the spec and at least to have a PIR backing it up!!!!!!.There were only ever one tester per branch when I installed these and no one ever new where it was!!!!so it was a thump on the glass and a rattle of car keys to test them,not exactly compliant I would have thought?.
Paul
