Guest rapapa Posted September 24, 2005 Share Posted September 24, 2005 Hello all, I need some help please. I am trying to get my mitsubishi HS-5424 to continually record after it has rewound to the start of the tape. I dont have the manual and would like to know if this function is available on this model. At the moment when it finishes recording at the end of the tape it automatically rewinds but stops recording. Thanks Link to comment Share on other sites More sharing options...
Rich Posted September 24, 2005 Share Posted September 24, 2005 Im quite sure there is a setting in the menu for it, have you gone through the menu system? Tape end: rewind and stop, rewind and record, etc. Link to comment Share on other sites More sharing options...
PJF Posted September 24, 2005 Share Posted September 24, 2005 This function is in the recording menu, I used to set all VCRs this way(before DVRs came along). Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time. Link to comment Share on other sites More sharing options...
Guest rapapa Posted September 25, 2005 Share Posted September 25, 2005 Thanks for the advice. It was on the menu, under 'repeat' function. Thanks again. Link to comment Share on other sites More sharing options...
