Guest fatfish Posted September 25, 2005 Posted September 25, 2005 hi all i have just installd a accenta 8 system it word ok but sum how i lot the codefor it and it wiil not go back to the factory set 0123 i have the engineering info book can sum 1 help
Guest Posted September 25, 2005 Posted September 25, 2005 Sounds like it might time to call an engineer then. There#s a link at the top of the page for installers if required. It could be a faulty panel but I suspect it may be user error.
Zak Posted September 25, 2005 Posted September 25, 2005 Did you mean that you installed it yourself? If so, and if you have installation manual, then it should tell you what needs to be done to correct the situation. Zak Tankel - Managing Director - Security First (UK) - www.securityfirst.uk.com Disclaimer: Any comments or opinions expressed by me are my own as a member of the public and not of my employer or Company.
Guest fat fish Posted September 25, 2005 Posted September 25, 2005 hello its me agen can sum 1 tell me wot a NVM is a how do i clear it o and thanks 4 the addvise
Zak Posted September 25, 2005 Posted September 25, 2005 fat fish said: hello its me agen can sum 1 tell me wot a NVM is a how do i clear it o and thanks 4 the addvise 69839[/snapback] Sorry, defaulting information is not permitted to be given out in this forum. If you don't have the installation manual (which you said you had) then there is nothing we can help with. NVM stands for Non-Volatile-Memory - keeps info even when not powered. You can always try calling the panel manufacturer.... Zak Tankel - Managing Director - Security First (UK) - www.securityfirst.uk.com Disclaimer: Any comments or opinions expressed by me are my own as a member of the public and not of my employer or Company.
Guest Posted September 25, 2005 Posted September 25, 2005 fat fish said: hello its me agen can sum 1 tell me wot a NVM is a how do i clear it o and thanks 4 the addvise 69839[/snapback] Sorry, are we texting each other now? Anyway, all the info you need is in the manual as has been mentioned. If it is unclear to you what you need to do then I suggest you call someone out for assistance.
Guest fat fish Posted September 26, 2005 Posted September 26, 2005 yer i have look at the engineering info and i no wot to do but it will not do it
Guest Posted September 26, 2005 Posted September 26, 2005 Only conclusion I can draw from that the is that the panel must be u\s.
Guest fat fish Posted September 27, 2005 Posted September 27, 2005 ok tanks 4 your time and your help
