lost code
Guest fatfish
If you have the engineer code, you can change your user code.. see back page of engineering book for engineer options... :console:
thanks but it is not working !!! the engineer code is the factory set 1 the alarm is all but working but its just not recognizing the code wen i power it up
Then the engineer code isn't the factory set one then is it.
