Guest ziph Posted October 28, 2003 Posted October 28, 2003 The problem I have now is programming. The installation manual is not very clear as to the programming method. The things I need to know how to program (preferably in a key press format, as its easier to understand) are... 1. setting zone 4 as a fire zone 2. changing the entry exit delay to a lower number ie. 10 seconds instead of the standard 50 seconds 3. changing the communicator format to allow the unit to dial my cell phone 4. changing the code from 4 digits to 6 digits 5. changing which zones are entry/exit zones if these could be provided in a key press format, it would be most appreciated. The only other problem I have is when i try to bypass zone 3 (the zone for my bedroom), as soon as the exit delay is over the alarm immediately sounds, which means I cannot arm the system at night. If you can help me with these problems, it would be most appreciated.
Guest ziph Posted October 30, 2003 Posted October 30, 2003 so nobody has any idea to help me simplify the programming procedure???? The only reason i'm asking is that the installation manual isn't very clear on the procedure needed...... If someone could explain it to me in an easier (ie. keypress) manner for even one of the functions I would be able to pick it up fairly easily, thus allowing me to program the rest of the features I require. I have emailed direct alarm supplies in Australia (the distibutor from which the original owner aquired the alarm) but so far no reply... So please someone must be able to help me....
morph Posted October 30, 2003 Posted October 30, 2003 You havn't had a responce as we are all mainly UK installers and this panel is not available here. If you can scan the manual and email it to us we will try and assist you. I am of course assuming that you are not in the Uk and are installing the panel elsewhere. Colin.
Guest ziph Posted October 30, 2003 Posted October 30, 2003 how right you are....I'm not in the UK....New Zealand to be precise.... I'll scan the manual tonight...... thanks for your response....
morph Posted October 30, 2003 Posted October 30, 2003 No Problem, with the manual we should be able to help and advise. Colin.
Guest dale Posted October 30, 2003 Posted October 30, 2003 Ahh, I thought I had never heard of the panel before? Obviously because its not available in the UK!!! Mebe we should have an international part of the site, for queries about systems outside the uk? Dale
morph Posted October 30, 2003 Posted October 30, 2003 maybe just a line on the forum header to say what country you are in?
Guest ziph Posted November 4, 2003 Posted November 4, 2003 my oh my.....what a pain in the ass this alarm has become..... Still no joy..... hmmmmm....
dinefwr Posted November 4, 2003 Posted November 4, 2003 I've got a copy of the manual if you want to see it Colin and Pete?
