Flash programmer
Has any one used a Texecom flash programmer to upgrade to a premier 48 to version 7 software yet?
If so did it work? & did you need to reprogram the full install?
Just wondering before I guinea pig a subscribers install
I tried upgrading to v6 and had problems as if it was corrupted, had to use v5.4 in the end.
I've read the books now it would seem that you should keep a back up via wintex before upgrading the firmware on panel.
Then the new panel software should have the new options as their default but rest of the system will be as programed,
Which brings me to another question, why do using two 7Ah battery NOT comply with PD662 :2004?
