aritech cd3403
Guest shane0
Guest shane0
Hi i have a Aritech CD3404 panel after having a new door replaced the alarm went off and everytime i try to set my alarm i have open door (back door) and a letter T i have rewired the contact but still can't enable alarm anyone help
Thanxs
Shane
I'm not the worlds greatest Aritech expert but it sounds like you have got the wires mixed up when you reconnected the contact.
Have you got another door contact on the system?
If so check that the wire colours in the one you reconnected match the other contact.
Regards
Bellman
Could it also be set for engineer reset on tamper?
Guest shane0
rewired contact the same as another door still no luck still saying door open with the tamper in front
Easy way to tell,
Shane, when you try to set it do you get an exit/entry sound or just error tone from panel?
If it's giving an exit entry sound, (May be different to the usual one but will still continue for the duration of the exit time). Then it's trying to set so is not set for Eng reset on tamper.
If you get an error bleep then silence then it's eng reset i'm afraid. :(
Btw, you may need to clear the tamper fault before it resets (told you I wasn't hot on Aritech)
Regards
Bellman
Guest shane0
Damn you guys are quick .lol run through what im doing
entering code
normal set
code accepted
system arming (no enter/exit tone )
open zone (s)
03 back door
try'd to inhibit zone
message not allowed
Thanks for all the help you guys
Sound like it's either your wiring that's incorrect or your contact is incorrectly fitted\faulty.
Check your resistors or wires are not shorting together. Its not set up for engineer reset as it would not allow you to get into the setting routine.
the CD34 is pretty basic and my moneys on a short, especially if you are using the standard surface contact with your resistors in the contact.
cheers Kev
It sounds like the resistors were built in to or hidden in the old contacts, and although you have connected the wires ok, you are missing a resistor or two.
If you don't know......ask.
Guest shane0
thaxs everyone the resistor thing looks like the problem as i cant find any apart from stomach pumping my dog i will have to reconnect using others last post i hope .lol could some one please tell me do i need 1 or two and what goes to what
thanx a million again
shane
