Guest shem Posted October 3, 2005 Posted October 3, 2005 Hi there! I've bought a property in withington/manchester which has the AJ600N unit installed. It's wired in as when i flick the power switch on/off the alarm goes on/off respectively. My problem is the previous owner didn't use it and doesn't know the codes or have any useful info whatsoever. Any ideas on how to get round this would be useful. Thanks in advance to anyone who can help with these 3q's.... 1.Does anyone know how to set/reset the A1 AJ600N without knowing the access codes? 2.Does A1 still exist as a company and can they help? 3.Is there a handbook with useful info available as a pdf? my email is shem@f2s.com !!!!
FASTCAR Posted October 3, 2005 Posted October 3, 2005 A1 went out of business years ago, and the AJ600 has very few friends, most of them were fitted by D-I-Yers.It sounds like your battery is either missing or defective.If the rest of the installation looks ok , get the panel swopped , or start again with a new install. There are plenty of installers available in the Manchester area. Regards. BTW did you try 1,2,3,4, ARM as the user code..
Guest shem Posted October 3, 2005 Posted October 3, 2005 Thanks for the advice!! I tried guesing and accidentally armed the unit. The internal alarm went off, followed by the external alarm. 30 mins, an extension ladder, hammer and drill later, my neighbours gave me a round of applause when I finally stopped it! Can anyone now recommend a company in manchester that won't cost the earth to come and fit a very basic alarm system to a 2 up 2 down semi?
bellman Posted October 3, 2005 Posted October 3, 2005 There are several companies on here that cover Manchester. A list is availible HERE. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
