Guest troll Posted October 28, 2003 Posted October 28, 2003 I have an accenta 8 alarm. The mains power was switched off by the plumber for an hour. When powered up again the strobe light activated. I tried to reset system on keypad but day and power indicators were off. I checked and am getting 13v power supply to keypad. I have checked the four internal fuses on the control panel and they are ok. Can anyone help me?
morph Posted October 29, 2003 Posted October 29, 2003 Power the sytem down again, wait a moment, reconect the battery first then the mains. Did you check the fuses with a multimeter? Did the panel make any sounds when you powered it back up? Did you disconnect the battery when you switched the mains off?( check the battery it may u/s) Colin.
Guest troll Posted October 29, 2003 Posted October 29, 2003 Power the sytem down again, wait a moment, reconect the battery first then the mains.Did you check the fuses with a multimeter? Did the panel make any sounds when you powered it back up? Did you disconnect the battery when you switched the mains off?( check the battery it may u/s) Colin. Thanks colin I didn't disconnect the battery when i depowered mains. I've done it now and all ok. Thanks
