PIR Entry/exit
Guest Guest_Simon_*
It sounds like you have prog the panel ok, but check again that zone 3 is type(6). You could try wiring the e/e pir into Z1, prog that back to(6), just to check the pir,cable & your prog is ok.
If all else fails I would default panel and try again or simply leave the e/e pir in Z1 :)
Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
