problem with veritas r8 panic button
Guest bustergut
Guest bustergut
Hullo
My four-year-old pulled the wire out of a panic button while we were decorating, and being an electro-dunderhead I am not sure how it should go back in.
The other panic button has blue and green wires attached to the circuit, with red, yellow and black unconnected.
But the detached button has no green wire - could anyone tell me how it should be re-connected.
If you can't, a certain four-year-old will have his pocket money stopped for the next 15 years until he has paid for it!
Thanks in anticipation
It could be that the green wire has snapped further back in the cable. Either that, or every detector is wired differently. To find out how it's wired you need to access the panel and find out which wire it is and follow the colours used there, which being a "electro-dunderhead", might not be wise!
Guest graale00
Hmmm, any resistors in the original Panic button before little fingers got to it?
  • 2 weeks later...
I would have to agree with lurch and it is most likely to be wired normally closed
good luck
:hmm:
